York Furnace
Old 01-12-08, 07:00 AM
L
York Furnace
I have a York Furnace 80 The furnace glow stick comes on the gas lites up and after 5 seconds the ignition goes out. It does it three times then lockes out due to non ignition. I though it was a presure switch.
Old 01-12-08, 08:39 AM
pflor's Avatar
I doubt is the pressure switch.
Prior to the ignitor's glowing-up, the inducer blower must have already been running and with the blower running if the pressure switch contacts do not engage, the glow-coil will not get its juice.
The board in your unit appears to be getting feedback from the flame-rod that no flame is present. Absence of flame causes the board to shut OFF the gas to the burners within 3-to-5 seconds after the gas valve started feeding them.
A common problem with flame rods is that they get sooty. Remove, clean-up gently with steel wool or a clean rag (I have even heard that rubbing it with a business card does a good job too) and re-install
Your Furnace 80 ???? this is far from being a complete M/N. Check the nameplate for it.
Old 01-12-08, 09:25 AM
L
York furnace
Thanks for the reply.
Like you said the fan starts, the glow stick illuminates the burners will start and 3 sec later it goes out.
The model # P4HUC20N09201A
Diamond 80 single stage upflow/horizontal (phu)
Old 01-12-08, 10:03 AM
L
It works
Thanks I took it out cleaned it. IT WORKS!!!!!!!!!!
Old 01-12-08, 10:12 AM
pflor's Avatar
furnace recall
Did you know about this notice?
http://www.cpsc.gov/cpscpub/prerel/prhtml01/01523.html
your furnace is listed there.
Having said that, did you check the flame-rod?
