Carrier 58PAV blower not coming on
Old 02-09-08, 02:25 PM
My furnace has been acting up the past month. The blower motor does not come on.
I replaced the thermostat with a new one but blower still does not come on.
I observed the heat come on (flames) but no motor. On the control board is a small 3 amp fuse, that checks out ok with an ohm meter.
Can someone please help?????
Old 02-10-08, 07:35 AM
Grady's Avatar
Received 23 Votes on 21 Posts
No Blower
You need to find from where the blower is powered & measure voltage. You should get 120 volts from the control to the fan. If you do, there could be a problem with the fan motor or capacitor.
