RobertShaw 780-715U
RobertShaw 780-715U
Hi Everyone,
I had an ignition problem on my Lennox heater for weeks. It would intermittently fail to ignite the pilot. Finally, a tech came by today and replaced the ignition module with a RobertShaw 780-715U. I think it's OK now except for one thing: when the furnace fires up, the ignitor continues to spark. I discovered that the flame sensor wire was disconnected from the module. So I called the tech to tell him about this and he said it's normal since the ignition module do not really require the flame sensor anymore. I would really want to believe what he said except that I want to verify from anyone that it is indeed OK that the module would continously send sparks while the heater is ON. Won't that cause anything to burn-out?
I looked at the ignition module and read from its side that it is factory-set for combined sensor/ignition wire. While it could take in a separate sensor wire, it says I have to remove the plug from the optional sensor terminal. Can anyone explain to me how this is done?
Thanks in advance for the help.
jr:
sparks should cease immediately once the pilot flame is present. We likely have here a case of miswiring of the module or poor grounding (or both).
Please post pictures (close-ups) of the control area (showing the module, pilot assembly, transformer, etc.) to help you further
