tiger loop
Old 03-08-08, 08:40 AM
tiger loop
Help! I have a forced hot air oil burner with a 1 year old tiger loop on system. Heat does not come on unless I push red restart button on blower. My question is, should my tiger loop have some oil in it all of the time? Is there an internal check valv failing?
Old 03-08-08, 11:06 AM
Grady's Avatar
TigerLoop
The TigerLoop normally would have some oil showing. When you reset the burner & it is running, is there fuel showing in the loop? Any foaming or air bubbles coming into the loop's bowl? If bubbles, from which fitting?
Old 03-08-08, 12:13 PM
after researching elsewhere i think the oil is getting sucked back by vacuum from clogged filter or lines.
Old 03-09-08, 09:13 AM
Grady's Avatar
TigerLoop
I would start by changing the filter. If that doesn't help, you can blow out the lines. I suggest using a bicycle pump adapted to fit the fittings on the line or a small compressor. Ideally, replace the line.
