Gas valve replacement for W.R. 36E97-201
Old 03-10-08, 09:21 PM
W
Hi,
what gas valve replacement can be / should be used for
WR 36E97-201 ( Intercity Products p/n 1585987).
Present gas valve (16 years old) still works - it is in Intercity Products GUI Series - Model GUI100AO12FIN (Comfortmaker RPJ / II ) nat. gas furnace.
I could not find much information from White Rodgers web site.
I did find Heil Quaker 1585987 as listed replacement (on the internet) but the gas valve seems to look different .
Any information will be appreciated.
Thanks
Old 03-10-08, 09:39 PM
pflor's Avatar
From the Janitrol/Goodman site:
Search for 36E97-201 returned the following item(s):
Description of Model Number Searched:
24V Main-Regulated Slow Open Manual Gas Knob Solenoid Line Valve
Suggested Replacement: None
White-Rodgers has no suggested replacement for this item. You must contact the manufacturer of the equipment it was used on for a suggested replacement or retrofit.
Descriptive Comments or For Whom Made:
Inter-City Products
Consumer Affairs Address
7401 Security Way
Houston, TX 77040
To speak with a Heating and Air Conditioning Consumer Affairs Representative from within the United States, please call 1-877-254-4729.
OR
Contact Us Online:
http://www.goodmanmfg.com/Home/About...6/Default.aspx
Old 03-10-08, 10:04 PM
W
Thank you for the information.
I did find the same or similar info on W.R. web site.
I am not sure if the 'goodmanmfg' web site will respond to my question since the furnace was made by ICP. I believe that ICP is part of Carrier ( I do not know that for sure) .
Perhaps someone had to replace that valve in their work experience and can post what they did use as a replacement.
The heating supplier suggested to use the Heil Quacker valve as a replacement - the WR 36E97-201 does not seem to be made anymore.
Thanks
Old 03-11-08, 04:21 AM
pflor's Avatar
Intercity products, Janitrol, and Goodman, are all the same company.
Carrier is to Bryant and Payne, Trane to American Standard
Old 03-12-08, 12:05 PM
W
Thank you.
Wes
Old 03-14-08, 08:12 AM
pflor's Avatar
Contact customer service at the following e-mail address.
The gas valve you're looking for is still a good part (is not obsolete). Tell them in which state you live and they will give you a bunch of names/addresses/phones of places that would sell the gas valve for your furnace.
GP CAR ICP Consumer Response (ICP) [ICPConsumerResponse@icpusa.com]
If you live in NJ NY PA CT or DE, I have names/numbers you could call. Just let me know.
Old 03-14-08, 06:50 PM
W
Hello again,
thank You for your response and your advice.
I have read a number of your posts ( other threads) and appears that You a very knowledgable and helpful person and I read ( and keep reading) your posts with great interest.
My knowledge in HVAC is somewhat limited even that I took classes for 6 months heating and 6 months AC, and then additional class to learn enough to pass the test to be EPA Certified for handling the refrigerants ( I got the "Universal" certification.
Some of my classmates actually started working in this trade ....... I just took the classes to learn something for my self and I am not planning to practice this trade.
My furnace is getting old ( same as I am) and I am sure it will require some parts before too long ..... or perhaps it will need to be repalced.
Every so often I see on ebay some parts that are reasonable in price ( some new, some used) and can be used in my furnace - that is why I did inquire about the gas valve.
I did find a local supplier that sells parts to 'do it yourself' .... but the prices are double or triple what I see them on the internet.
I live in Michigan and did find the gas valve in a local "do it yourself' supplier for 170 dol. Since I do not have to have yet .... I will let them keep it until I needed.
Pflor, I do thank You for your help and do appreciate it.
Wes
