Goodman furnace doesn't work
Old 03-12-08, 08:15 PM
B
My furnace is about 5 years old. It doesn't give any heat out since yesterday. I used digital thermostat.
Here is what I found so far:
1. Air conditioning is working fine (cool).
2. When I set fan to "on", it does blow out the air.
3. when I set my desired temperature at very high( like 95 deg) and fan to "auto" mode at "heat" mode, Neither air or heat coming out.
4. The manual says this furnace doesn't have pilot, it has an device to auto ignite the burner
Then I opened the thermostat and tried the following:
1. connect red(RH) and White(W), the blower under the burner seems "on" but I didn't see air out from duct.
2. connect red(RH) and green(G), I can feel air coming out of duct but no heat still.
Anyone can give me any hint how to fix it? Is it thermostat problem or furnace issue?
Thanks.
Jack
Old 03-13-08, 02:53 AM
pflor's Avatar
Pls provide the full model number of this goodman furnace.
The problem is not on your thermostat.
Do not turn the cooling mode ON during cold weather (winter) unless you live in FL, CA or TX, else you risk damaging the compressor $$$
