Honeywell VisionPRO IAQ Stat
Old 03-13-08, 06:53 AM
L
Thumbs up Honeywell VisionPRO IAQ Stat
I recently installed A Coleman Echelon Modulating up flow furnace 9.M series 100K. I hooked up the Honeywell IAQ thermostat to it. Does anybody know the best settings for this type of furnace with this type of stat?
Do you treat it as a 2 stage, 3 stage or conventional. Any info will be greatly appreciated. I want the furnace to function at the best efficiency.
Old 03-13-08, 05:34 PM
KField's Avatar
I don't think you can set it for multi stage because there is only a single input on the furnace. The boiler modulates the input based on length of heat call or air temp. I would set it for 90% or more efficient when it comes to cycle rate.
Ken
Old 03-14-08, 03:58 AM
L
Thanks, I really appreciate the insight.
LV
Old 03-14-08, 05:28 AM
KField's Avatar
Sorry
I said boiler but I knew it was a furnace from your post.
Ken
Old 03-14-08, 05:34 AM
Jay11J's Avatar
Just set it as a single stage heat, at 3CPH. I'd hate to say this, this stat is an over kill for your furnace.. You could of gotten by with the Regular VisionPro TH8110, unless you have a two stage A/C and has dehumidity control, and humidifier.
Old 03-14-08, 05:42 AM
L
Thanks for the info. I do have the stat controlling the humidifier and with outdoor sensor also the A/C is a two stage system.
Thanks Again,
LV
