CAN I USE k1 KEROSCENE OR DIESEL
Old 03-27-08, 08:41 PM
K
i AM LOW ON OIL ,GAS STATION HAS K1 KEROSCENE ,THE OIL TANK IS IN MY BASEMNT SO COLD IS NOT AN ISSUE. CAN I USE THIS OR SHOULD I LOOK AROUND FOR DIESEL?
Old 03-28-08, 05:55 AM
pflor's Avatar
Check your burner manual.
Beckett is O.K. with diesel (no mention of kerosene though).
What's the brand of your burner?
Old 03-28-08, 03:51 PM
K
label szs belcher its an old one
Old 03-28-08, 06:30 PM
pflor's Avatar
humm...
I've never heard of them.
Old 03-28-08, 08:25 PM
Grady's Avatar
Received 23 Votes on 21 Posts
Diesel or Kero
If you normally burn heating oil (I don't mean kerosene), either will work ok. I wouldn't suggest using kero long term because the pump is probably old & kero can be tough on pumps due to it's lack of lubrication.
Old 03-28-08, 09:34 PM
K
thanks, i'll use diesel for a couple days until delivery arrives
Old 03-28-08, 10:25 PM
Ed Imeduc's Avatar
Wink
The diesel will just cost you more than your PINK fuel oil is all. Thats for the road tax. That KEROSCENE here I saw it at H/D for $34.00 for a 5 gal can.
