transformer failures
Hey
I have a Beckett AFG oil burner in my house. Last year or the year before the transformer failed and a tech replaced it. It was a Beckett Model BLL101 10kV. The tech swapped in a Beckett 51771U which just failed last week. I put a screwdriver on the springs and there was no spark so I went to the store and got a new one installed it and I had fire again.
Are these 2 different transformers direct swap parts or should I expect my new one to fail in a 2009 too? Thanks for any tips.
Received 39 Upvotes
Ignition Transformer Failures
The 51771U is the electronic replacement for the old 10 kV iron core. Make sure the furnace is properly grounded & scratch some paint off of the transformer around the screw holes where is mounts to the burner chassis. Bad grounds are a common cause for electronic parts failure.
Thanks Grady!
Received 39 Upvotes
Iron Core vs. Electronic
Iron cores are far more forgiving of incoming voltage fluctuations. I have some very rural accounts where voltage fluctuations are a problem & have had to use iron core transformers.
