Furnace Problems
Old 11-19-00, 03:48 PM
Post
Please help we are having problems with our furnace. We have to continuely manually turn our blower on and off just to get it running. Then if were lucky it will run half the day/night then it turns off. We wake up in the night because it so cold, because the furnace has shut off. To get it going again we flick the blower switch on and off. We had 2 different heating services supposely fix it;just to have it continue what it always does. We have lived in our house for 3 years now and every winter this happens.
Old 11-19-00, 03:52 PM
R-12guy
Post
what kind of furnace? Gas, oil, Heat pump?/?? where are you doing this with the fan switch?
Old 11-19-00, 03:56 PM
fjrachel
Post
More info needed. Type of system and turning your blower on and off at the t'stat should have nothing to do with the heat, unless you have a bad blower run cap or motor
Old 11-19-00, 04:02 PM
Post
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by R-12guy:
what kind of furnace? Gas, oil, Heat pump?/?? where are you doing this with the fan switch?<HR></BLOCKQUOTE>
The furnace is gas and fan switch is on the
thermostat
Old 11-19-00, 04:05 PM
fjrachel
Post
Have the run capacitor on the blower motor checked.
Old 11-19-00, 04:12 PM
Post
thermostat
