NO heat, No action
Old 11-20-00, 05:02 PM
Question
I have a Lennox Whisper heat gas heating system. it is hooked to a humidifing system. It ran for about a month, and just recently stopped. There was a lot of water coming down the front of the heater, so I turned the humidifing system off. Unsure of how to turn off the water running to system. I also have the Honeywell thermoatat, which is reading -AC even when it is set to heat. This just happened today. Any suggestions to what might be the problem, and what would I have to do to rectify the situation. Thanks for any help possible.
Old 11-20-00, 06:08 PM
fjrachel
Post
Call the Lennox repair man..The AC on the stat means it has lost it's program. If it is hardwired, you also may have lost a transformer, probably due to the water.
