Lennox Pulse fan won't stop
Old 06-22-08, 07:18 PM
B
My Lennox Pulse has been perfect for fifteen years. Now that I put my house up for sale it is retaliating. The fan motor will not stop running after a cycle. The only way to get it to shut down is to turn the power off for an extended time. I tried to turn it off then back on right away but it must need a cool down period. This was in the AC mode but I didnít try it with the heat. I would have to guess but I bet it would do the same.
Any ideas?
Old 06-23-08, 04:35 PM
E
Do you know that the cycle has indeed finished, with the thermostat shutting off? Or, if you set the temp higher (while in A/C mode) it still does not shut off? Do you have a round mercury or digital type thermostat?
Have you tried to check anything yourself, and if so, what?
