Pilot Generator Voltage
I live is SW PA. I am having trouble with my Natural Gas swimming pool heater. The heater is a Pentair (PUREX) 150M CH MiniMax. This heater uses a millivolt control system with Honeywell components. The pilot burns steady but the burners won't fire. Following the schematic, I have tested the various limt and pressure switches (safeties) and they all read OK. The burners will fire up using a jumper across the TH and TH-PP terminals of the gas valve. I have also used a jumper to fire the burners in a way that includes the safeties.
The pilot generator terminals read 470 mV.
I read on another forum that a minimum of 500 mV is needed to open the gas valve. I changed the pilot generator. The new one reads about the same. I used a C battery to booster the voltage up to 1.5 mV and the burners fired. I used a propane torch to heat the old pilot generator and I was able to get 740 mV. I am stumped. Does anyone have a suggestion on how to proceed?
Received 41 Upvotes
Pilot Generator
If the valve opens when you use jumpers, the generator is putting out enough to operate the valve. I suspect you are getting a voltage drop somewhere. This is quite possibly due to corrosion, a common problem with pool heaters. What is the Honeywell number on the pilot generator? Knowing that, I can find out the rating. The number off the gas valve would also be helpful.
The pilot generator is a Q313A 1170. It is rated at 750 Mv. The Valve ia a VS820.
I just found some interesting specs for the control TS820A millivolt control system. You can check it out at
http://vancontrols.com/pdf/hw/TS8205.pdf
I'll report back after some more trouble shooting. I recently bought a very nice multimeter and I have been looking for a chance to give it a workout. I just hope the rain holds off.
BTW: Thanks for the reply.
gsharpe
gsharpe
Problem solved
The problem turned out to be a corroded slip connector on the sensor lead. I cleaned them up and the unit is running just fine.
Thanks for the help.
Received 41 Upvotes
All Fixed
Good job. With outdoor equipment or pool heaters exposed to the pool environment, corrosion is a common problem.
Coating the connections with electrically conductive grease may help to prevent future problems. This grease is available from any auto supply store. I use it on all the electrical connections on my boat & it really helps.
Connector coatings
Is this the same as the dielectric grease that is used on the connections in meter sockets and breaker panels?
I used CRC 226 contact cleaner. However I have noticed that it doesn't protect from future oxidation.
On another note:
I am trying to find a compact AC evaporator coil for a house I am refurbishing. The plenum is only 18.5 in. deep, 16.25 in. wide and 30 in. high. Any suggestions? I may be able to use a separate air handle, but it must be a downflow model with top or rear inlet and a right side outlet.
Thanks,
Greg
On another note:
Thanks,
Greg
