Adding 3 way bypass valve
Old 09-16-08, 03:32 PM
Question Adding 3 way bypass valve
I have a Lennox downflo oil furnace with a honeywell 5 wire CT 31 thermostat. I have just installed a water to air heat exchanger under the furnace. I want to install a Taco 560 3 way bypass valve so my water will keep circulating and heat my DHW.Do i need to hook the bypass valve to a seperate thermostat? How do I keep the blower working for the heat exchanger and not have the oil kick in?
Thanks, Greg
Old 09-17-08, 03:56 PM
Jay11J's Avatar
I just saw your post, I am going to have to a little research on this and get back to you..
is this water coil getting hot water from a wood boiler?
Old 09-17-08, 04:37 PM
Jay11J's Avatar
ok, What made you go with this valve?
Is the pump running all the time? (or what controling that?)
Is there A/C on this furnace?
Old 09-17-08, 04:52 PM
Thanks for the reply! The heat is from outdoor wood boiler,the pump will run all the time and if it would help I can get a different valve. No a/c.
Old 09-17-08, 05:12 PM
Jay11J's Avatar
Ok, we may need to look into another valve.
The one you picked has a 120 volt side for control like a pump or burner.
i am heading out for dinner, and will eb back later.
Old 09-18-08, 05:35 PM
Grady's Avatar
Wood Fired Boiler
Do you intend to keep the oil burner in service as a backup? If so, you would probably be wise to get a two stage thermostat.
Old 09-18-08, 06:37 PM
Ok I will look for a two stage thermostat. Do you know what brand of 3 way zone valves does not have a 120 volt side?
Old 09-18-08, 07:50 PM
Jay11J's Avatar
Any 3 way valve that is only 24 volts will work.
Grady may have more info on his hand since he around hot water heat more than I am.
That is what I was planing on doing is use the 2 stage t-stat like Honeywell RTH7400 model.
Old 09-19-08, 05:13 PM
Grady's Avatar
Thanks, Greg
Greg,
Several questions popped into my head after re-reading the original post.
1. Do you realize the 560 is only a 1/2" valve?
2.I don't understand the part about heating the domestic. Are you heating the DHW via an indirect & is it not on a dedicated zone?
Old 09-19-08, 07:03 PM
The DHW is in the main line before the heat exchanger. I found a valve to use it is a siemens/powers MXE series 24 volt 3 way diverting valve without a 120 side. I am going to get a RTH7400 thermostat probaly tomaro then i just need to know how to wire the thermostat up.
Old 09-19-08, 07:23 PM
Someone in another forum says i need to use a seperate 24 volt transformer for the zone valve or you i will burn mine out is this true?
Old 09-19-08, 07:27 PM
Jay11J's Avatar
Guess it depends on how big the zone valve will be.
Look at your current transformer and see what the VA rating is... it it turns out to be to low, then just need to upgrade the transformer to a stronger one.
Old 09-19-08, 07:38 PM
My transformer is a 40VA what else do i need to know if that is enough
Old 09-20-08, 10:52 AM
Grady's Avatar
Taco Zone Valve
I didn't see where the Taco valve has any 120 volts connected to it & should you ever need to replace the power head, I'm sure the one for the Taco would be much easier to find.
http://www.taco-hvac.com/uploads/FileLibrary/100-3.pdf
Maybe I'm a bit dense on how the DHW is connected but having the domestic & a space heating coming off the same loop sounds really strange & could lead to gross overheating of the domestic. If you could take some pics of the system, post them on photobucket.com or similar photo sharing site, & provide us a link to the pics, it might help this old dummy understand.
Old 09-20-08, 10:56 AM
Transformer size
40 va may be enough, but it may fail if your house voltage goes low. I like to use a 75 va with built in fuse or breaker. That way if it trips you have a chance of trouble shooting the circuit without buying an expensive tranformer replacement. A taco valve usually pulls 1.2 amps on it, close to the 40 va limit. Also if more controls are on this circuit it might go.
Old 09-20-08, 01:08 PM
Jay11J's Avatar
You are not the only one Grady, I am thinking the same thing as you are too.. "The house hot water is going to way too hot"
Old 09-20-08, 01:27 PM
Grady's Avatar
Domestic
The only way I can envision where a setup like this would be safe would be to have the domestic heated via an external heat exchanger. In an external exchanger application the boiler water is pumped thru one side & the domestic thru the other & back to a storage tank. The domestic pump would be controled by an aquastat on the tank.
Old 09-21-08, 09:37 AM
The DHW is heated via a side arm water heater. I got the RTH7400 thermostat. Now I have to get the valve and maybe a 75VA transformer to be safe.
Old 09-21-08, 10:16 AM
Grady's Avatar
Transformer
No need for a 75 VA transformer. A 40 will handle up to 3 zone valves.
The side arm water heater has a separate bronze or stainless circulator for the domestic side & circulates from & to a storage tank?
