Basic Oil Burner operation information.
Hi all,
I recently finished converting a small oil furnace to burn waste oil, specifically used transformer oil removed from X-ray equipment. I've learn a lot about the burner (a standard Beckett AFG bought on Ebay) and the basics of how a furnace operates, but now I want to test the combustion efficiency and learn more about the stack, it's various components, how flue height effects draft, and other things like that. I modifed the burner by installing a pre-heater in-line between the oil pump and the nozzle. The burner and the furnace work great! But I want to test the flue gas and other parameters so that I can tweek its performance and efficiency. Could someone please point me to a good web site that explains basic information about oil burner efficiency and how the design of the stack affects it? Thanks very much!
