Trane xl 80 blower not working
Old 10-10-08, 10:30 AM
Z
I have a Trane xl80 about 14 years old. The ignition is fine--I turn on and the fire goes about 5 minutes and it was really warn. But the blower not working and ther fire will die in about 5 minutes. Really need help.
Thanks.
Old 10-10-08, 03:13 PM
Jay11J's Avatar
Does the blower run when you set the t-stat's fan switch from AUTO to ON?
If nothing happens can be a couple of things... But if the fan does run, then we need to get the meter out to see if you are getting power on the "heat" tap on the board.
Old 12-21-08, 08:40 AM
It doen't seem that this issue was discussed after your reply. I have the same problem and NO, the blower fan does not come on when I swithch from auto to on.
Old 12-21-08, 06:50 PM
Jay11J's Avatar
You need to get the meter out and see if you got power coming onto the tap where the blower motor wires up to on the board.
