Determine Furnace size by Heat Loss/Gain
Old 10-11-08, 01:06 PM
Received 1 Upvote on 1 Post
Could anyone tell me how to determine the size furnace I need according to the following info:
House Size: 2400
House Style:Colonial
Total Heat Gain: 33,047 BTUH
Total Heat Loss: 84,163 BTUH
The existing furnace is 165,000 BTU but it is well oversized. Any help is Greatly appreciated....
Old 10-11-08, 03:23 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Furnace size
You need a furnace with an output large enough to cover the heat loss (+/- 85,000 btu/hr). If you use a 90+% efficient furnace you'll likely end up with one with an input of 100,000.
Old 10-11-08, 06:42 PM
Thank You Grady,
So I should probably go a little larger, correct? Like 110,000 or 115,000?
Old 10-11-08, 07:46 PM
airman.1994's Avatar
Received 8 Upvotes on 8 Posts
No longer run times = better money savings
Old 10-12-08, 01:03 AM
user 10's Avatar
Received 57 Upvotes on 50 Posts
84k is a bit high for 2400 sq ft. unless you live in a really cold climate.
Do everything you can to reduce heat loss prior to replacing the furnace. (Draft proofing should come first, followed by adding insulation)
Old 10-12-08, 09:44 AM
I live in New York State -it's cold. My info comes from a Free Heat Loss Estimate from http://www.hydronic.net. To double check it, does anyone know where I can get the Heat Loss Formulas to calculate them myself??? I am a math person as well as a programmer so I'd like to double check the accuracy of their software...
Old 10-12-08, 03:09 PM
Grady's Avatar
Heat loss/gain calculations
There is a free heat loss program available from Slant Fin.
http://www.slantfin.com/heat-loss-software-get.html
I don't know of any free heat gain programs but one of the best costs $50 & is available here: http://hvaccomputer.com
It does heating & cooling.
