Lennox Model G40UH -Fail to Lite
Old 10-29-08, 12:24 PM
Unhappy Lennox Model G40UH -Fail to Lite
I have a Lennox G40UH Furnace 'professionally' installed with new home 5 years ago. No problems till now. It will not start when thermostat heat control is initiated. Trouble Code Lite = Dis1 Off/ Dis2 slow flashing "Pressure switch open/condensation line blocked/Pressure switch closed prior to activation of air inducer etc..." ??? I cleaned Sensing Rod w/steel wool..still nadda....Codes Normal at start-up then default to above when Furnace fails to lite??? Did notice that fuse on circuit board schematic calls for 3a fuse but 5a fused installed/matching 5a switch???? No problem for past 5 years. SOooo... Don't know if that is significant or not??? Anyone have any trouble shooting/repair suggestions? Help its getting COLD here in VA.
Thank You
Len
Old 10-30-08, 03:58 PM
Jay11J's Avatar
Check the hose on the pressure switch, also remove the hose off the small inducer fan housing, and check to make sure that port is not plugged..
If that is clear, then make sure the hose is not cracked or came undone on the pressure switch.
