Carrier 9200 Weathermaker Furnace/AC
Old 11-04-08, 06:55 AM
Question Carrier 9200 Weathermaker Furnace/AC
I have a carrier 9200 gas furnace that works with the carrier ac heat pump/ac unit outside. when i purchased it i was told the gas furnace comes on when it is 40 degrees or below outside. With the price of propane at 4 bucks a gal i would like to know if and how i can chance the setting for the furnace to come on? thanks
Old 11-04-08, 10:26 AM
Jay11J's Avatar
Yes, you should be able to drop the temp down lower.
Where are you out of?
What t-stat is being used, and model # of it, or is something else is being used to switch system?
Old 11-04-08, 01:40 PM
tln1947
Thanks for your response Jay11J.
I am using the programmable thermostat by carrier. when it registers 40 or below on the sensor that displays outside temp on the TS it automatically switches to aux heat which is the furnace. the TS manual says as a note that for additional energy savings ask your dealer about locking out aux heat at a selected outdoor temp. Exactly what i want to do-right?
Old 11-04-08, 01:43 PM
tln1947
sorry, i am living in va near williamsburg
Old 11-04-08, 02:26 PM
tln1947
i have found the model # to be TSTATCCPDF01-B.
on the inside it also says
c-no low temp lockout
i assume this TS does not have the option of changing temp from 40 default. right?
Old 11-05-08, 07:27 AM
Jay11J's Avatar
I am having a hard time finding the install/set up manual.. I am going to keep on looking for it.
I found the owner's manual, but it don't say anything about this.
Old 11-05-08, 08:38 AM
tln1947
c-on=no low temp lockout
revised on nov 5 2008
thanks for all your help
Old 11-23-08, 06:09 PM
what was the answer? do you just flip that switch? I have the exact same problem,and wonder how you resolved it.
Thanks!
Gene
