thermostat and heater issues
Old 11-08-08, 06:10 PM
Ok, i decided to look at the back or my motherboard to see why my fan wouldnt click on to find out a solder blew out on the relay. So in doing test i came to the conclusion it was more than likely saveable. So i labeled all my wires, easy, took it off, fixed it, and re-installed it. But now when i flip my breaker to power it my ac condenser turns on...no fan. All switches on thermostat are off. Then i realized i didnt hook up the white wire from the thermo to the board. Now i realized i messed up wires again.
So here is what i have... Please help me figure out where they go!
On the board there is spots labeled C G Y W R and i have a white,yellow,red,green, and blue wire going to the thermo and a red and brown wire that hooks to the board that run to my condenser unit.
Obvioulsy at my thermostat i have a white,yellow,red,green,and blue wire and a thermostat labeled G RC RH Y W.
I must add that the blue wire is not used and i have a jumper wire available. My thermostat is a hunter 44110.
Please help ASAP!
Old 11-08-08, 08:43 PM
Jay11J's Avatar
This how it should be wired up.
T-stat------wirecolor-----furnace.
Rc/Rh*-------Red----------R
Y----------Yellow-----------Y
w---------white------------W
G--------green-------------G
Then two wire from A/c outside from furnace.
Y------red
C------brown
