Riello Mectron 3 How do I restart?
Old 11-09-08, 08:52 AM
D
Question Riello Mectron 3 How do I restart?
I have a Riello Mectron 3 burner on my forced air furnace. I ran out of oil and now that I have oil it will not start when I turn the power on and turn the thermostat up. I remember this happening before and I had to remove the cover loosen a bolt and get oil flowing but I can't remember how i did it. Can anyone help? Thanks!
Old 11-09-08, 12:16 PM
Jarredsdad's Avatar
There is a large reset button on the burner, should glow red in lockout.
If you are looking at the left side you'll see the oil pump. At about 5 o'clock is a bleed screw. It's 3/8", reset the lockout and open the bleed when the motor starts to bleed air.
May have to do this a couple times.
Old 11-10-08, 07:55 AM
D
Thanks for the information. I'll give it a try.
