patriot 80 furnace won't start
Old 11-23-08, 06:56 AM
I have a patriot 80 forced air furnace 2 yrs old w/ beckett burner w/ 2 zones. At the end of last yr the tstat was calling for air at 70deg furnace kicked on and heated the house up to 70 and kept heating and blowing before i realized it the house was 80deg. I shut the main off and didn't turn on the furnace until 2 wks ago. The furn. kicked right on heated up the house and then kept heating. Turned the main off. Reset the system purged the system. The furnace hasn't turned on since. Any thoughts? It's getting cold in ct. Thank g for the wood stove, but i won't be home to feed it all the time.
Old 11-23-08, 01:08 PM
Grady's Avatar
Patriot 80
I'm confused. You say it is 2 zones & you purged the system which implies hot water but the only Patriot 80's I've seen are warm air & you refer to it as a furnace.
Is this a furnace (warm air) or a boiler (hot water)?
