Getting a Code 31 Error on Furnace Payne Model GB3AAV
Old 12-12-08, 12:36 PM
Okay--I checed the blinking LCD and get a Code 31 Error, which says to check for a number of things:
Proper Venting Size and Consensate pitch
Vent Restriction
Defective Inducor Motor or start capacitor includng venting
Defective Pressure swith or connections. If it opens after trial for ignition period, blower will come on for 90 second recycle delay.
Disconnected or Obstructed Pressure Tubing
Inadquate Combustion Air Supply
Low Inducer Voltage
Now if I reset the error with the door switch (i.e., just push in the switch that would be pushed in if you put the service access door back on) or pull plug out and put back in, the blower comes on for 90 seconds and then shuts off. This problem was intermittent for a couple days--the heater would come on later at night, but now doesn't come on at all.
I jumpered that pressure switch and then off course got an error that the the Pressure Switch Did not Open.
Any suggestions on troubleshooting this further?
I thought about checking the venting tube from the unit to the roof, which is very short since the unit is in the attic, but I don't know how to take that apart. I thought it would just pull apart--is it connected somehow? How do you take that apart to check venting restriction or is there another way?
Old 12-27-08, 11:10 AM
Same problem
I have the same problem with my furnace. Were you able to find the problem? It sounds like I've tried the same tactics for trying to solve the problem. I will post when I find out the problem.
Old 12-27-08, 12:17 PM
Skip4661's Avatar
Vent Restriction
Low Inducer Voltage
If you have a lot of snow on the roof you may want to make sure the vent isn't covered. Does the inducer fan start up after the 90 second blower.
Also model and serial #s would help.
