Furnace shutting off and starting up before desired temp
Old 12-20-08, 05:53 AM
L
We just had a new Westinghouse Furnace and thermostat installed last Jan. we have not had any issues with it till this week. For some reason the furnace is shutting off before the desired temp is reached then starting back up again. It only stays on for a couple of minutes. What is going on? It's cold in here.
Old 12-20-08, 06:55 AM
Grady's Avatar
Received 23 Votes on 21 Posts
New Furnace
I suggest calling your installer back. If there is a problem, other than something like a dirty air filter, they should take care of it.
Old 12-20-08, 07:45 AM
Yes, call the installers back. you should have a 1 yr. warranty, It is also possible that you are getting a drop in gas pressure. "GO COLTS"
Old 12-20-08, 07:50 AM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
Before you call them, have you been changing the filters as required? If they show up and it's dirty filters, you'll prob be paying for a service call.
