Rheem Fan Limit Switch
Old 12-31-08, 11:19 AM
My Rheem furnace Fan Limit Switch is broken and I'm searching for a place where I can order it.
The furnace part number is: FGLJ-10EBRJR
Switch part numbers as they are printed on the limit switch:
J9720 Mexico
36T01B3 42261
L220-20F
47-22679-07
Thank you everybody for the help!
Erandas
Old 12-31-08, 12:01 PM
SeattlePioneer's Avatar
Furnace fan limit switches are increasingly an obsolete part uncommon in modern furnaces these days. Trying to find an exact replacement is probably going to prove difficult.
But you can probably find a part that performs the same functions, wither from the same manufacturer or another like Honeywell.
I'd take the old part into a furnace distributor or retailer and they can probably fix you up with a suitable replacement.
Old 12-31-08, 04:46 PM
Grady's Avatar
Fan/Limit
From the looks of the numbers that sounds like just a limit.
Old 12-31-08, 04:48 PM
Skip4661's Avatar
Is it really broken or is it causing limit faults with the furnace?
Old 12-31-08, 05:00 PM
You are right.... limit only, opens at 220 degrees closes at 200 degrees
Old 12-31-08, 07:21 PM
Rather than telling us that the part is bad, why don't you tell us what you are observing that seems to be a problem?
Old 12-31-08, 09:01 PM
Are you sure?
furnaceparts.com lists a replacement limit switch for your unit. But I echo SeattlePioneer's comments. How do you know it's the limit switch?
Old 01-03-09, 12:55 PM
To answer the question about what is (was because I finally after 2 weeks of searching found a replacement switch) broken.
The blower fan was constantly running. I pulled the fan limit switch. It was open at any temperature.
Found the replacement part, put it in and finally after two weeks the house is heated again.
Thank you for the suggestions!
Erandas
