Weathermaker 9200 error code help
Old 01-03-09, 08:12 AM
My furnace is displaying error code by led: 1 short and 4 long. I don't know what that means. The thermostat will start the AC but no the heater.
Any help is appreciated.
Thanks
Old 01-03-09, 01:25 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Error Code
If the code is coming from an ignition module please post the make & model number of the module.
Old 01-03-09, 01:38 PM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
Also, I'd suggest you take the cover off the burner compartment and carefully observe and report what happens when you turn the thermostat up to bring on the furnace. I'd do this several times until you are satisfied you aren't missing anything.
Let us know what you see and hear.
