parts for old International series 950 furance
Old 01-04-09, 11:34 AM
Trying2Help's Avatar
Received 11 Upvotes on 8 Posts
Question parts for old International series 950 furance
Daughter has a series TAC 950 furance installed in a trailer house she is renting. She was complaining that the heater wasn't working and the landlord hadn't done anything, so I went over to look at it.
What I found was this: The cord to the motor was frayed and shorted out where it went into the housing of the motor. Also seems the upper limit switch was not working properly.
I took the motor apart and rewired it, however, it doesn't not spin fast enough to move air properly. So am thinking there must be some bad windings in the motor and needs to be replaced. I can stop the squiral cage with my hand, so there is very little torque being applied to the cage also.
My problem is I can not find any listing of parts for this heater anywhere. All the information I have is listed below, if anyone can point me in the right direction it would be appreciated.
Furance: International 950 Series
Input: 43,000 BTU
Output: 33,000 BTU
Ser #: L953TAC8JE17D10
Limit Switch: Part #: C4870-7-63
F120-1
Motor: International Oil Burner Co.
St Louis, Missouri
115 Volt
60 Hz
1.7 Amps
Ser # 5523978M
1050 RPM
Mod. 36-032
Fits models : TAC 900 950-1&2&3 1033-1 1043-1
Thanks in advance.
Old 01-04-09, 03:48 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
International
I don't think they are still in business. If that is the company I think it is, they were bought out by Nordyne many years ago.
