Chimney pipe damper flap
Old 01-04-09, 03:07 PM
C
I have a small problem with the damper coming out of the side of the pipe that connects my furnace (oil, forced air) to the chimney.
Mounted in the damper is a metal flap (Field Controls 320H) that's supposed to swing on two pins -- one pin per side.
Today I noticed that one pin was gone and the flap was lying inside the mounting. Fashioning a new pin was easy, but the flap is designed to swing either in or out, not both ways. A tab on each side prevents it from swinging freely.
When the furnace runs, should the bottom of the flap swing in or out?
Thanks
Old 01-04-09, 03:45 PM
Grady's Avatar
Received 23 Votes on 21 Posts
Barometric Damper
I searched Field's site & couldn't find that model. Generally if the pins are above center, the bottom would tip in, if below center the bottom would tip out.
Old 01-04-09, 04:16 PM
C
The pins are above center. Thank you very much.
