Furnace Running
Old 01-05-09, 11:45 AM
D
Furnace Running
I have a 25 year old Luxaire forced air furnace that constantly cycles on and off. The blower will run and stop after a minute or so and then start up again and cycle on and off at varying durations.
Does anyone have a clue as to what is going on?
Thanks,
Dan
Old 01-05-09, 11:49 AM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
You need to describe in detail what is happening. That means taking the cover off the burner compartment and noting the sequence of events that is happening. You need to do that several times until you can derscribe what you are seeing and hearing in as much detail as possible.
The amount of detail you provide will determine how much help we can be.
