Help needed selecting furnace
Old 01-08-09, 08:38 PM
N
hi
I need to change my old and failing natural gas furnace, I will be helping a certified master mechanic (working with a large HVAC contractor - he works on the side during weekends) to do the change.
I have two options of furnace from which to select and need opinions on which one would be better. My heating requirement would be 70000 btu.
Furnace - 1
Manufacturer: RUUD
Model: UGFD-07EMCK
AFUE: 92.8%
Features: Multistage firing with constant low speed fan. two speed induced draft fan
Furnace - 2
Manufacturer: York
Model: Latitude TG9S Series Gas Furnaces
AFUE: 95.5%
Features: Single-stage Gas Furnace
The price difference between the two is pretty small and the warranties are more or less comparable.
Which one is better with respect to:
1. Reliability and potential problem areas
2. Availability of spare parts in future
3. sound levels
Thanks in advance
Old 01-09-09, 05:16 PM
xpogi's Avatar
The York 95% furnace will qualify for a one time $150 tax rebate and perhaps depending on your installation and climate, another $50 savings in fuel costs every year.
By the way, how did you determine you need a 70000BTU furnace? If your old furnace was 70000BTU and assuming it is 78% efficient, that means it is delivering 54600 BTUs of heat. A York 95% 60000BTU furnace would deliver 57000 of heat.
Old 01-10-09, 08:26 AM
B
As long as both units are installed properly, it is most likely a wash. I'd go with the York for the money saving down the road. Fuel prices will only sky rocket for the next few decades.
