TACO and LUX thermostat
Old 01-14-09, 04:54 PM
H
Please help. I have installed a new LUX TX9000TS thermostat but the heat does not kick on at all. I have propane heat and two heating zones in our home. Here are some pictures. . . don't know where things went wrong. .
Old 01-14-09, 06:51 PM
Skip4661's Avatar
How is the thermostat wired? Where are the wires connected to on the stat.?
Old 01-15-09, 06:13 AM
H
Thank you for responding.
Red wire to R. White wire to Rh and a jumper wire from Rc to Rh.
I have two heat zones in the house. This may or may not be an issue but I am using two different thermostats in the house. The t-stat in zone 1 is the LUX and the t-stat in zone 2is a Hunter.
Old 01-15-09, 07:04 AM
Skip4661's Avatar
Leave the jumper for rh-rc, wire the red wire to rh and the white wire to W. This should take care of your problem.
Old 01-15-09, 07:23 AM
H
Sorry Skip I misspoke. . . the white wire is in W and the red is in Rh, and the jumper wire runs from Rc to Rh.
