Furnace fan issues
Furnace fan issues
I recently purchased a house and the fan on the furnace constantly runs. I checked the thermostat wiring and it seems correct. it is a two wire system with a separate air conditioning unit that was installed at a later time. The fan continues to run even when I disconnect the thermostat. Can I assume that something is wired incorrectly between the air and the furnance?
Please post the make and model of the furnace, which can be obtained from the rating plate for the furnace, usually found in the burner compartment.
What do you mean by "its a two wire system" ? Are you saying you have a furnace with an indoor A/C coil and a condensor outside operated by one stat that only has two wires hooked up to it ?
Or, do you have a 2-wire, heat only thermostat? And a separate thermostat for the a/c? If you have a separate a/c stat - what is that set on? Mention all settings. For instance - it might be possible that on the separate a/c stat, the stat is set to a temp below current room temperature, and the outside a/c compressor-fan condensor unit's disconnect is shut off, but the temp setting is still calling for the furnace fan to run, since the furnace fan is what delivers the cold a/c air when that stat comes on. And maybe it is on! The reason this could happen is the fan's "G" wire is twist-tied together down in the furnace, in parallel between heat and a/c.
If the above is not it: And if you just bought the house -unless they are very firm about some "as-is" clause, you might contact the realtor or seller and ask them to see if the ex-owner can shed some light on what they might know. It's worth a shot, anyway.
thanks for the reply. we have only one stat. but i will cleck the wiring for the air conditioner to see if that is the problem. i did kill the power to the furnance and removed the wires from the stat. then turned the furnance back on and tne fan still ran.
I do know this much -something is not right the way you are explaining the stat having 2 wires then, if you have both central a/c and heat. Does that stat then control both the heat and a/c? We need to get to the bottom of that issue. Can you answer dun11's question then? And fully describe the stat.
