noisy riello 40 f5 burner
Old 02-25-09, 12:40 PM
i have a noise that seems to be coming from the burner motor. Is this a common problem or should i be looking for something else?
thanks,
mike
Old 02-25-09, 02:22 PM
P
What type of noise might be helpfull
Old 02-25-09, 04:41 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Motor(?) noise
The easiest way to determine if the noise is coming from the motor is to diconnect the fuel pump from the burner body & start the burner. If the noise persists, the motor bearings are probably going bad. It may also be helpful to remove the air inlet cover just to make sure the fan is not rubbing against the cover or burner body.
