High winds and No Heat with Lennox Gas Boiler GWB8-ie
  #41
Old 04-30-09, 06:59 AM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
Originally Posted by tedz532
Note- the fan spins clockwise -as it should - with the updraft condition but it spins very fast with high winds preventing start up of boiler -sometimes- depending on the speed.
Some ignition control modules wont start the furnace if the pressure switch is stuck in the closed position when a call for heat occurs. I wonder if the chimney draft could be high enough to cause the pressure switch to close, causing this kind of condition?
That might be an explanation for why the boiler will sometimes fail to operate.
  #42
Old 04-30-09, 07:45 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Damper
If I wouldn't use it in my own home, I would not have suggested it. If installed properly & the damper fails to open for some reason the burner will not fire.
