Copper pipe sizes (gas)
Old 04-20-09, 08:32 PM
H
Hi, i'm new to DIY. I just ran a new gas line connecting to existing system. However I found out after I ran it that I bought the wrong size. The existing is 1/2" soft copper OD (even the main pipe) and the new line I ran is 1/2" ID. Can anyone tell me if that is going to be an issue? I ran it about 45 feet, thanks in advance.
Old 04-20-09, 09:21 PM
P
Temporarily Suspended
I don't know if I would use copper for gas but I'll let someone more experienced answer. If it's ok, a street coupling might solve the problem.
Old 04-21-09, 02:23 PM
P
Sounds like you used plumbing copper which is measured by ID
Gas tubing is OD
Old 04-21-09, 04:59 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Gas in Copper
In my area we are not allowed to run gas in copper. We must use black steel pipe or CSST. I much prefer the black steel pipe.
Old 04-22-09, 11:20 AM
H
Gas tubing is OD
Hmm..I hope you are wrong :-) since I used the type L copper which is good for gas. I'm in Minnesota and they use soft copper for gas all the time. Can anyone confirmed the statement above? Thanks.
Old 04-22-09, 02:37 PM
P
You'd have to check with someone in your area to be sure.
We use soft copper here too, but it's rated for gas use and it's not type L
