Lennox Pulse not kicking on since power outtage
Old 04-25-09, 07:59 PM
T
I have a Lennox Pulse nat gas Furnace, GS14 series, installed in 1998. Serviced 11 months ago.
Was working fine this morning, this afternoon we had a 20 minute power failure here. Furnace has not worked since.
I don't know if the power failure is related/cause to issue, but here are the details.
Pretty sure furnace was running when power outtage occurred.
Fan works in 'on' postion, no heat.
Fan will not kick on in 'Auto' postion.
thermostat readout says 'heat on'
but no heat.
Checked all breakers, etc.
Thanks in advance.
Old 05-02-09, 05:55 AM
Jay11J's Avatar
Have you reset the breaker, to reset the ignitor control?
If you have, the pop the cover off and on the left upper corner is where the ignitor control is at. You should see a LED light, and I don't recall what color the lights are going to be, but look on the box to see if there is any error codes info.
I may be guessing that may had a surge when the power came on.
