Capping an unused gas line?
I recently purchased a home, and the sellers left a Buck Stove Vent Free fireplace. My husband and I don't want it and want to disconnect it properly from the existing gas line it is connected to. How do we do this? I see where the line connects in the wall, and it looks like I can use a wrench to release the line with the gas to the house turned off, and then we cap it somehow? Any advice would be appreciated. Thanks!
Temporarily Suspended
Look for a second shut off valve, one that only works for the stove line. Then, you can buy a cap & some pipe dope. Cap the nipple & it's done. Some people use teflon tape with the pipe dope. Others don't.
are we talking about the valve inside the house or outside the house? the connection to the wall is just like screwed on there, I don't see a valve other than the shutoff on the actual unit.
We are talking about inside the house. There is a main valve inside at the gas meter. There may be another valve on the line that goes to the stove. Trace the pipe to where it meets the main line. If there isn't a valve, then you will have to use the valve at the meter. If that's the case, all pilot lights, if any, will have to be lit again after the job is done.
