Beckett Oil Furnace Won't Start
This looks like an informative forum, so here goes...
I have a Beckett AFG Oil Burner, installed in 1997, that won't start. Normally every year the furnace starts when called upon. I have checked AC power, I have clicked the manual fan switch, and the fan runs just fine. Normally pushing the reset causes the furnace to cycle, but not today. Silence.
I have looked at new ignitors, but they appear smaller than mine, which is large and has the large red reset button. Mine is large square, and has the red button on top. Underneath, there are two copper strips, not the coil springs I see on the new models, is this an update?
New Models...
New Models...
Received 40 Upvotes
Copper Strips?
I can't recall Beckett ever using copper strips on their ignition transformers. Are you sure the burner is a Beckett or are you just looking at the ignition transformer? Beckett makes ignition transformers to fit many different burners & all their transformers will have the Beckett name on them regardless of the brand of burner.
If the thermostat was calling for heat, you pressed the reset button, & nothing at all happened, the ignitior is not your problem.
