Problem with old Rheem gas heater
Old 10-10-09, 11:14 AM
P
I'm having a problem with our old Rheem natural gas heater model #3600-80ADA. The house is 33 yrs. old and I suspect this is the original unit since it matches the other unit in the house.
My problem is with keeping the pilot lit. When I switch the regulator from pilot to on, the flame will stay lit for about 45 seconds. I then hear a subtle click and the flame goes out a second later. I am no pro but I suspect there is some safety switch being triggered that is cutting off the gas supply in the regulator.
Any guidance or recommendations would be greatly appreciated.
Old 10-10-09, 02:12 PM
P
Nevermind. I read another post where the problem may be a bad thermocouple or dirty one. I cleaned off the thermocouple tip and the pilot light area and was getting a much better "forked" flame.
It is working now. I guess I just wasn't getting enough flame to the thermocouple.
Old 10-10-09, 02:18 PM
D
Too late, you already fixed it.
Delta
Old 10-11-09, 02:41 AM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
Cleaning the tip of the thermocouple is not enough. You need to remove and disassemble the pilot burner and clean (sometimes replace) the pilot orifice and the pilot burner.
