Gas furnace burner won't light, also short cycles
Old 12-07-09, 12:51 PM
P
We have a Janitrol gas furnace that is probably 15 years old. The pilot lights and stays light, but the main burner will not light. We hear the igniter clicking and buzzing, and then after about a minute, it gives up and stops. If we fan or blow on the front of the furnace during the buzzing of the igniter, the main burner will light, and the furnace will run. It does blow hot air and works good once we get the burner lit. However, it usually won't run until the temp is reached - it'll go up 2-3 degrees then the fan stops, it'll relight the main burner, and then the fan blows again - continuing this 2-3 times to raise the temp say, 8 degrees. My husband tried cleaning the flame sensor but that didn't seem to help.
Suggestions?
Old 12-07-09, 02:44 PM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
What is the model number of the furnace?
Old 12-07-09, 05:55 PM
P
I looked at the sticker inside and it says Model GUI 125 5A Rev S.
