Goodman GMPN 120-5 Furnace Will Not Heat
Old 12-08-09, 06:24 AM
Same exact problem as the one posted in this thread:
http://forum.doityourself.com/gas-oi...-goes-out.html
But my model is different and I cannot see any sensor rod to clean....any suggestions would be appreciated.
Storm coming in tonight so I would like to resolve this as cheaply as possible before calling in professional (costly) help.
Thanks
Old 12-08-09, 07:02 AM
Fixed the problem. It was indeed the sensor rod -- found it in another location. It came up underneath the far right burner, accessible by removing a screw and connected by a grey wire. I was able to pull it out, sand it down...and Voila...problem resolved.
This forum is great. Excellent info form other posts...saved myself at least $150 for the service call (at a minimum).
Old 12-08-09, 05:30 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Fixed
Way to go. Glad you were able to find an answer in an old post. It is absolutely amazing how many times we get the questions. Congratulations on doing a bit of research.
