older tempstar forced air heater
Old 12-09-09, 02:31 PM
A
my problem is that there is a small barrel type fan at top front of unit that sucks carbon monoxide out of unit and vents it out the roof on the houseing of the fan is a nipple that conects to a sensor by a hose to tell it its ok to ignight and run because the vent fan is working execpt my vent fan is not is it possible to buy this fan motor or do i have to just replace whole unit thank you
Kevin
Old 12-09-09, 02:45 PM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
The vent fan is commonly called the inducer fan or inducer motor.
The sensor is called the pressure switch.
I take it that the inducer motor is seized, up, squealing or otherwise not working properly.
My suggestion would be to shop around for a replacement inducer motor assembly that includes the motor, fan and that portion of the housing that screws the assembly into the furnace.
Rather commonly the fan gets seized up on the motor shaft and is difficult ---often very difficult to remove.
Buying the entire new assembly will make it a lot easier to install.
In my experience, it's smart for DIYers to do things the easy way even if that involves spending a few extra bucks.
