How to remove the inducer motor in my bryant furnace
Old 12-12-09, 08:34 PM
D
Ok..so I thought it would be easy to remove my inducer motor in my Bryant Furnace. I started to remove a few screws and I realized that the squirrel cage fan is enclosed in sheet metal. I thought once the screws were removed the whole part would easily pop out. I was wrong. It doesn't look like it was spot welded, just tightly bent to enclose the fan. Below are some pics. Are there any manuals out there to help me? Specials tools to open it up? There's got to be an easy way. Suggestions?
http://i199.photobucket.com/albums/a...o/IMG_0016.jpg --Here you can see the whole mechanism
http://i199.photobucket.com/albums/a...IMG_0015-1.jpg --Here is a close up of the enclosed squirrel cage
http://i199.photobucket.com/albums/a...IMG_0013-1.jpg --Here is another look at the whole mechanism
Old 12-12-09, 10:09 PM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
Ummm. Just going by the usual Carrier assembly strategy, I would expect that you'd need to remove the three screws with the rubber washers behind them ---
The two vertical screws at the top, and one in the middle at the bottom. That wont work? Usually there a gasket that requires moderate prying to release the inducer motor assembly.
If not, what's the model number of the furnace?
Old 12-12-09, 10:50 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
The screws highlighted red will allow removal.
Old 12-12-09, 11:31 PM
Those were my second choices. I think you're right though, Houston.
Old 12-13-09, 09:50 AM
Houston204's Avatar
Unless he is replacing the entire inducer assembly (which I recommend) we are both right.
