Beckett AFG primary controller problem
Old 12-29-09, 12:57 PM
I have a Beckett AFG oil burner that is giving me a problem. It makes a clicking sound when trying to start. The clicking sounds like a solenoid opening and closing rapidly. The sound is coming from the terminal on the primary controller.
Here is what I did:
I moved the two wires that come out of the bottom of the terminal. I cant access where they connect in the terminal. I'm guessing that they are soldered and one came loose.
Should I replace the primary controller?
Old 01-01-10, 01:24 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Sorry for being slow
You probably have replaced the control by now & solved the problem.
I applologize for missing your post previously.
