Fan won't turn on manually
Old 01-02-10, 07:06 AM
R
The fan on my system won't run when I switch the fan switch from "auto" to "on." Other than that, the system works normally.
The switch worked fine until recently. What can I do to troubleshoot this?
Old 01-02-10, 10:56 AM
SeattlePioneer's Avatar
What's the make and model of the furnace, which can be obtained from the rating plate in the furnace burner compartment?
Old 01-02-10, 12:14 PM
R
Coleman direct vent forced air furnace - model 7956B856 - (mobile home)
Old 01-02-10, 12:50 PM
Grady's Avatar
Received 35 Votes on 33 Posts
Fan ON
I wouldn't worry with it but if you really want it to work we can do some troubleshooting. Do you have A/C & does the furnace fan usually run when the A/C is on?
Old 01-02-10, 01:26 PM
R
I do want to go to the trouble to fix it as I use it often.
Yes, I have A/C and the fan does run when the A/C is on.
Old 01-02-10, 01:38 PM
Grady's Avatar
Fan Problem
Remove the thermostat & temporarily install a jumper between terminals R & G (a paper clip will work). If the fan comes on, the thermostat switch is bad. If no fan, remove the jumper, turn off the a/c AT THE BREAKER, set the stat for cool & well below room temp. If still no fan, it's likely a relay in the furnace or the fan motor's cooling speed is shot.
Old 01-02-10, 02:48 PM
R
I shorted R and G and the burner started. No fan, just the burner as if I had raised the setpoint.
Old 01-02-10, 03:02 PM
Grady's Avatar
Something's wrong
No way should jumpering R/G bring on the burner. Either try the A/C test or repeat the R/G jumper test at the furnace terminal strip. If testing at the furnace, leave the stat off the wall.
