True Blue
Old 01-02-10, 02:39 PM
A
True Blue
I have a tech 4 true blue 90 im not sure what the problem is but it has to do with pressure switch. when i turn on thermostat nothing happens but if i go and open heater pull the 1/4 hose off the the 2" pvc going outside and give the hose a little suction the fan comes on and after 30 seconds the furnace lights and works fine the other end of the 1/4 hose goes to the pressure switch. can anyone help me with this its a strait temp of -4 in north WI
Old 01-02-10, 03:10 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Pressure Switch
Check the exhaust & intake (if two pvc pipes outside) to make sure neither is blocked. Is there a steady plume of steam coming out of the exhaust while the furnace is running?
Old 01-02-10, 07:19 PM
Skip4661's Avatar
You may be getting water in that tube and it won't let that switch open after a heat cycle.
