Cold house-t-stat or blower problem???
Old 01-04-10, 11:01 AM
H
Question Cold house-t-stat or blower problem???
AMANA 80 SSE BLOWER NOT WORKING. WOKE UP THIS AM TO COLD HOUSE.WENT TO THERMOSTAT AND MOVED LEVER UP TO WHERE HEATER WOULD COME ON.COULD HEAR SOMETHING TURN ON(MAYBE FURNACE )BUT BLOWER NOR HEAT DID NOT COME ON.THEN WHATEVER CAME ON WENT OFF AFTER ABOUT FIVE MINUTES.PLEASE HELP.HARD FREEZE EXPECTED IN 3 DAYS. HAVE KIDS.....NOT A LOT OF MONEY.
THANKS IN ADVANCE
Old 01-04-10, 11:21 AM
SeattlePioneer's Avatar
I'd start by taking the cover off the burner compartment of the furnace and locating the rating plate, which should be inside.
Get the model number off the rating plate and report it here.
Next, turn the thermostat down so that the furnace shuts off completely. Then have someone turn it up and observe the sequnce of events which happens as the furnace attempts to start. You might need to repeat that several times until you have grasped the details of what is happening.
Report that sequence of events here as well.
Old 01-04-10, 12:06 PM
H
Wink Follow-up
THE MODEL NUMBER ON THE ISDIE OF THE PANEL IS b1422801.WHEN THE T-STAT IS MOVED TO MAKE THE HEATER COME ON THE FURNACE FIRES RIGHT UP.YOU CAN HEAR FAINT CLICKING SOUNDS BUT NOTHING ELSE.THE FURNACE TURNS OFF.NOTE*****THE CAPACITATOR LOOKS BRAND NEW. NOT BULGING OR BURNT
