Mueller Climatrol Fuel Oil Furnace Ignitors
Hi,
I'm on the desperate hunt for replacement porcelian ignitors for my VERY OLD Mueller Climatrol Fuel Oil Furnace. My brother has filed them to the point where he can't do it any more.
The Furnace is:
Model: 218-100
Serial:1 D P
Input: .75 gal per hour
Bonnet Output: 80,000
The above was on the furnace itself not the motor.
I'm near Chicago, ILL but if I have to order parts from somewhere, that's fine. I'm just tired of freezing our rears off.
Any help would be GREATLY APPRECIATED!
The Furnace is:
Model: 218-100
Serial:1 D P
Received 39 Upvotes
Electrodes
Your best bet is to go to a local oil dealer who has a service department. If they deal with Sid Harvey, they can probably get the electrodes you need. In some areas, Sid Harvey will sell to homeowners, in some areas they won't. Here's a link showing locations. Home Page
If you go either to a Sid Harvey store or an oil dealer, be sure to take the electrodes with you. They probably won't be able to find anything based on the furnace make & model.
