Gaspack no heat..Help !!!!
Old 01-31-10, 10:48 AM
O
My house has a trane gaspack, model ycco3of1mobc, mfg. date 1994. We just had an ice storm here in nc and i just returned home after being gone for 1 night. I left the thermostat on 68 but when i came in and turned it up noticed it was not putting out any heat. I went outside to unit and the vent is not warm as usual. The ac works fine but when i switch back over to heat it will come on and run for a couple or 5 minutes or so and then cut off. Its like it is not igniting the gas or either the gas is not there. I have trid turning the unit off at the thermostat and turning back on after 10 minutes but does nothing....Any suggestions would be appreciated....thanks
Old 01-31-10, 04:20 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
If you can you get to it, what trouble code is flashing? (page 19)
http://www.trane.com/webcache/un/roo...l_11012003.pdf
