york gas furnace on the fritz.
Old 02-11-10, 05:21 PM
R
i have a york furnace whose inducer motor went bad. it caused a error code#9(grounding/ line polarity fault). replaced the inducer motor. but i still have error code #9 that wont reset and furnace wont even run now. i have checked polarity on 120 volts and 24 volts everything checks out fine. just the error code seems to have locked the system. any ideas?
Old 02-11-10, 10:43 PM
SeattlePioneer's Avatar
Why did you replace the inducer motor?
The error code your describe would not be a reason for replacing the inducer motor.
Sounds like a failed ignition control board which might cause erratic operation of the inducer motor and diagnostic codes that don't make sense.
